in
The Yamaha Road Star Warrior Forum
The #1 site for the Yamaha Road Star Warrior
Power Commander PCIIIUSB Version 2007
Last post 08-06-2008 11:14 PM by Arizona Warrior. 51 replies.
Page 1 of 4 (52 items) 1 2 3 4 Next >
Sort Posts: Previous Next
  • 06-20-2008 10:33 PM
    I received this email from Dynojet Researech in response to my inquiry:
    When the units were first made we did not have access to the TPS connector. Recently we did acquire the TPS connector so all units now are being shipped with the TPS connector on there. If you want to send the unit back to us we can update the harness and ship it back to you. With the new harness the "perfect install" is not required.
    Mike Shefler
    Dynojet Research Inc.
    1-800-992-4993 EXT 1109
    Dyonjet is stepping up to the plate like any world-class company should, in fact thery are doing better, they are coming forward and offering it right out.  This is a great reason for everyone to buy Power Commander - especially if its the new RSWarrior version with the TPS plug!
    Filed under: ,
  • Sponsored Links
  • 06-20-2008 10:37 PM In reply to
    • gman
    • Top 50 Contributor
    • Joined on 10-09-2006
    • Kalispell MT
    • Posts 4,036
    • Supporter
    Re: Power Commander PCIIIUSB Version 2008
    Thanks for the info Arizona. Mine is all done with the Perfect Install, but that is great info for new installations.
    Less Government = Less Taxes and More Freedom - gman
    Taxation WITH representation ain't so hot either - Gerald Barzan
    I used to care more - gman
  • 06-20-2008 10:49 PM In reply to
    • love_snot
    • Not Ranked
    • Joined on 03-29-2005
    • Campbellsport WI USA
    • Posts 68
    Where's the best place to buy, price and with knowledge that we'll for sure get the new warrior version? I've shopped around a bit and looked through the forums but I want to be sure to get that version if possible.
    My favorite number is blue!
  • 06-20-2008 11:02 PM In reply to
    If it hurts, your not dead yet.
  • 06-21-2008 1:06 AM In reply to
    • phat-azz
    • Not Ranked
    • Joined on 09-15-2007
    • Sydney - Parramatta NSW, Australia
    • Posts 120
    dhousedog:
    Ditto. Got mine from there too.
    Thanks, Ari. Luckily, I haven't done the perfect install yet.
    Hasta la vista... hombre!
  • 06-21-2008 12:51 PM In reply to
    I've asked DynoJet a follow-up question to get the answer for those of you asking about how to know if you're getting the newest model when you buy on-line, and is there a part# change to indicate the TPS plug upgrade.
    I bought my PC3USB in early 2004 as model# 1020-0078.  I've checked my unit and it does not have the TPS plug so I'll be sending it back for updating.
    Now, this could be meaningless but as we all know the current partl# is and has been for some time 403-411 HOWEVER this doesn't mean much because googling both part#'s returns the same information for the same PC3USB.  It could be that one part# is for dealer use and both are the same exact identical unit.  So I asked DynoJet if this part# difference specifically indicates the TPS plug improvement which does not need perfect install.  I also asked how long ago the TPS plug was added, it might have ben awhile ago.
    Those of you who want to buy a PC3USB and want the most advanced unit, hang in there I'll post their response for you.
    Those of you who have a PC3USB and want to know if its the newest model, look at your bike and notice if the PC3 came with a complete TPS plug, or if you added a couple wires to the existing TPS wires.  If you added wires, you can either do the perfect install or you can remove the PC3USB and ask DynoJet to update it with the TPS circuit and plug instead.
    It would be nice to know if anyone already has the PC3USB with complete TPS plug, who of course did NOT do the perfect install, and if they have verified that their set-to-zero-throttle idle is rock-steady when tuning, and on up the throttle% scale is also rock steady when tuning.
    Finally, I do NOT know what will happen if you have a new TPS plug version and do the perfect install anyway.
    That's all I know for now.
  • 06-21-2008 1:05 PM In reply to
    I just purchased mine about a month ago and it was just plug and play. Everything seems to be okay. Bike runs like a charm and changing maps while running seems to be good. 0% throttle seems correct and throttle position all the way through seems correct and steady with the readout.  Did not have to do perfect install. Don't know if this helps?
  • 06-21-2008 1:47 PM In reply to
    Yes it does help to confirm there is no need to do the perfect install for the newest RS Warrior version of the PC3USB.
    EXCELLENT!
    Alberta Warrior:
  • 06-21-2008 8:11 PM In reply to
    i am sooooooooooo glad i brought this up earlier. thanks  arizona warrior for taking the time and rersearching this...... my throttle %is rock steady...and the accelerator pump feature is pretty cool so far...
    tearing it up for 4 months . and fixing it in 8 months
  • 06-23-2008 12:22 PM In reply to
    Re: Power Commander PCIIIUSB Version 2007
    OK this should answer all the questions.  Lets just say that Jan07 the new version with the TPS plug became available and for awhile both versions shipped under the same part#.  Now just the version with the TPS plug is shipping from Dynojet.  You're on your own so if you buy from a vendor see if you can get a straight answer but they probably don't know about this upgrade.  Here's the response:
    The change was made about a year and half ago, but we still had old harnesses made so both units were shipping for awhile. The part numbers are the same. You just have to look to see if you have the connector or not.
    Mike Shefler
  • 06-23-2008 1:04 PM In reply to
    • davidd
    • Top 500 Contributor
    • Joined on 04-09-2007
    • central MN USA
    • Posts 337
    Okay, I'm not real smart when it comes to these things-as I do not have one yet.  If I buy this new version with the TPS plug I do not need to do the perfect install?  Is that true?  If that is the case, how hard is it to install one of these?  I have been dreading doing the install for a while, but feel that I could have some fun with a PCIII and new pipes.
    Forgiveness is between them and god....it's my job to arrange the meeting.
  • 06-23-2008 1:07 PM In reply to
    In case helpful the revised installation manual for the Warrior PC3USB on the Dynojet website covers the new model and shows the TPS plug:
    http://www.powercommander.com/downloads/403/install/411/eng403-411.pdf
    But don't rely on just looking at the manual that came with your unit, lay eyes on your bike for the existence of the TPS plug to avoid confusion.
  • 06-23-2008 1:12 PM In reply to
    The unit with the TPS plug is now plug-and-play as far as connecting the wires.  The install manual has pictures:
    Anyone who can read and use a screwdriver can install this newer PC3USB to a Warrior.
    That being said, the unit then has to be adjusted to match your mods.  There's plenty of help on this site and it helps to have a laptop so you can be at your bike in real-time.  There could also be nearby members who can stop by to help out, you'd have to start a new topic and ask around.  Finally, a good pro dynotune is beneficial so actually you can install the unit and leave in on zero-map so it'll do nothing yet, then ride it to a tuner and let them hassle the tuning.
    davidd:
  • 06-23-2008 1:15 PM In reply to
    I just bought one a week ago from Dennis Kirk and upon examining it Scawein discovered it's the one they considered plug and play but NOT the newest one with the seperate TPS (perfect install) plug seperate.  Another interesting thing I noticed was that on the package it made mention of 411 but also said something like "410 for 411" as if the model number had changed.  A year and a half sounds like a completely unrealistic timeframe for DK to have this in stock so I'm not sure what to think of that.  Did they mention what the turnaround time is if you send it in for conversion?
  • 06-23-2008 2:05 PM In reply to
    Excellent thread. Thanks for taking the time to research it for the rest of us.
Home | Forums | Photos | News | Classifieds | Warrior of the Month | Contact Us | About Us | Donate | Advertise | Legal & Privacy
©2002-2008 RSWarrior.com. All rights reserved.
Site designed and maintained by CarKnee Consulting
